Bds lift kit 2003 2500hd
Vmyrhaug
2003 lb7sac45 35" 20x12 fjallasport flares
Mar 6, 2016
177
41
Norway
I have a bds 7" lift kit on hand.
How will the height be with torson max unloaded vs stock cracked full up?
Sorry for my bad english, still an retard from norway
Blackmax123
683
central Pennsylvania
Are your subframe a full 7" drop? I would guess from your stock keys cranked to the max to the 7" lift and your torsion bars unloaded you'd be looking at around 5" higher with the lift.
Vmyrhaug
Mar 6, 2016
177
41
Norway
The mesure on subframe drop is 14,2cm. 5 and 3/4".. how much do they lift from bottom too max on torsjon?
Vmyrhaug
Mar 6, 2016
177
41
Norway
The height adjustment on stock Key is not more than 2"?
From all out too full crank up?
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
French Creek, West Virginia
Depends on how wore out your torsion bars are but usually 2" tops is what you get on the stock keys with the bolts buried up.
Lifts come with leveling keys so they'll be higher off the bat with no bolts.
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
Ever take a ride in a wheelbarrow as a kid? That'll be your ride comfort if you crank your keys with that kit. I have the exact same Kit on my LMM and I turned that thing down right after. Rides MUCH better now. Just my personal experience.
Nick
Vmyrhaug
Mar 6, 2016
177
41
Norway
The plan is to install bds, and make it as low as possible but still have suspention travel.
Blackmax123
683
Not true with all lifts. Some companies market a 6" lift or could be 7 , 9 or whatever. But they set the lift up with brackets that are 2" less then the stated lift hieght then leveling keys are used to gain the stated hieght.
But some companies market their lift to that the height if the brackets are. So by I stalling it and setting your stock keys to the same position the body's were will net you the stated lift height.
The zone lift on my lml is stated to be 5". The lower control arm drop brackets are exactly 5" on bolt centers to where they bolt to the team and where the a arm bolts in. No I run my stock keys turned down about 3/8" lower than stock was. My tv's are almost level and truck rides better than it did stock..
