Been working on this for a while now...
This has got me confused.
Pulled the 482BBC out of my wagon, couldn't get it to stop backfiring, especially when cold. Never had a miss or studder.
Basic build spec, MK6 BBC STD bore and 4.25 crank, FT pistons +3cc valve relief, 113cc chambers puts CR ~9:1
280TFS heads, 224/234° .050" .630/.640"(1.8 rockers) 114lsa, RPM intake, 650cfm carb, HEI ignition.
Tube headers with 1-7/8 primary and. 3" collector.
(Yes I know the carb is small, also not plan on buy another carb when plan is to put MPFI and a 1000-1250 Throttle body on the engine)
Did everything thing I could with engine in the car, compression test had holes #2/#3 at 150psi everyone else at 160psi. Technically that's in spec, but have less than ~50hrs of run time it's a point of interest.
Fast fwd, pull heads, i find the cause of the backfire exhaust for #2 #3 don't have good seals and have signs of blow bye through the valve seat interference area..
What I didn't expect to find was the following.. and has me and few others confused
4 holes that look roughly normal
2 look almost new (#2/#6) with #2 having more carbon build up than #6
#1/#5/#7 round out the middle. I'm carbon build up. Plugs are black, but I set the carb up very much on the rich side.
decks on both the block and heads are good, cam isn't flat, no signs of blown HG or cracks for coolant to be washing the cylinder down, exhaust never smelled like coolant either.
Any ideas to why the clean holes?
I've got a fresh set of OEM MK6 heads, that I had done as a set of spares.
Part of me wants to see what TFS's warranty is about.
