When you charge the batteries in these trucks and you hook up your charger to say the drivers side does it also charge the passenger side battery at the same time? My assumption is yes
I bought new batteries awhile ago but when my truck sits for a few weeks the batteries do draw down . Although my truck will start I know they aren't up to full potential so I like to charge them up as you aren't doing your electrical system any favors by not doing so. Basically I start it up move it only let it run for about 15 mins as it's inside then shut it down then repeat to put it back in it's out of the way spot. So IMO this labors the alternator the batteries and starter and wiring doing this so I charge my batteries.
Friday I put the charger on the DS and there was a significant amp draw. When I came in the AM it did not show a complete charge so nonetheless I hooked up the PS and there was a min amp draw in with in a matter of a few minutes the battery was fully charged.
With the old batteries when I did the exact same procedure it seemed the PS battery took longer to fully charge but not as long as the DS and I assumed that battery DS was junk. The batteries were old enough to be changed out anyway.
So do they charge together or do I have a bum battery? Also do I only need to hook up to one battery to charge both if they charge together? I am assuming they charge together,at least I hope so.
