Banks cold air intake
295PRO
Jan 30, 2015
I'm putting on my lb7 and had a buddy tell me I need to have motor tuned before I install it. I'm curious as to if this is true. If so, why?
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Thats gasser talk...
Install the intake and drive, enjoy
Awenta
4,090
CT
No, it just feeds the turbo.
Only time is has to be tuned is if the intake tube is a different diameter. Then the map sensor has to be adjusted.
295PRO
Jan 30, 2015
Ok thanks.
AKlowriderZ71
May 14, 2012
719
Wyoming
It's just a LB7 thing. If you do a search on any of the diesel forums, you'll find this info. And it will be better explained than I can do.
