balance rates
Barlow
Barlow
Apr 19, 2009
120
Mississippi
i checked balance rates today on my ppe excellerator... just watching it at idle they were all 2.9-3.1 except one was 2.5-2.6 is this cause for alarm?
blowinsmoke
obsessed not addicted
Nov 24, 2009
21
limits
You are correct bro. GM says +/- 4 in Nuetral and +/-6 in drive with engine at operating temp. You dont have to compare any cylinders to each other like some say. #1 can be at +5 in drive and #3 could be at -4 and everything is all good. You understand what the + and - is right?
+ is addin fuel to injector and - is taking away from injector
+ is a lean cylinder and - is a rich one
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Let me ask you guys this question with built trannys. After you installed everything and put in your tripple disk converter did your balance rates change? Mine went up slightly on my lbz after I built mine. Just wondered if the extra weight and mods done the if engine needed more fuel to maintain the idle speed the computer wanted to see?
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
Mine will be different with different tunes I have loaded. My lowest balance rates are with the stock tune loaded.
