is this good or way off?
PRI CAPTION DESCRIPTION VALUE UNITS MIN AVG MAX PARAMETER SYSTEM
1 STATE15-APP1 APP 1 In Range . In Range In Range In Range GM.STATE15 State
1 STATE15-APP2 APP 2 In Range . In Range In Range In Range GM.STATE15 State
1 STATE15-APP3 APP 3 In Range . In Range In Range In Range GM.STATE15 State
1 APP1 Accelerator Pedal Position Sensor 1 Voltage 0.5 V 0.5 0.5 0.5 GM.APP1 Sensor
1 APP2 Accelerator Pedal Position Sensor 2 Voltage 4.5 V 4.5 4.5 4.5 GM.APP2 Sensor
1 APP3 Accelerator Pedal Position Sensor 3 Voltage 4.1 V 4.1 4.1 4.1 GM.APP3 Sensor
1 FRPACT Actual Fuel Rail Pressure 5062 PSI 4851 4986 5118 GM.FRPACT Fuel
1 BALRCYL1 Balancing Fuel Flow Rate Cylinder #1 -0.53 mm3 -0.78 -0.59 -0.41 GM.BALRCYL1 Diesel
1 BALRCYL2 Balancing Fuel Flow Rate Cylinder #2 0.63 mm3 0.61 0.89 1.08 GM.BALRCYL2 Diesel
1 BALRCYL3 Balancing Fuel Flow Rate Cylinder #3 -0.20 mm3 -0.48 -0.38 -0.20 GM.BALRCYL3 Diesel
1 BALRCYL4 Balancing Fuel Flow Rate Cylinder #4 1.22 mm3 1.13 1.20 1.28 GM.BALRCYL4 Diesel
1 BALRCYL5 Balancing Fuel Flow Rate Cylinder #5 -1.33 mm3 -1.75 -1.46 -1.22 GM.BALRCYL5 Diesel
1 BALRCYL6 Balancing Fuel Flow Rate Cylinder #6 0.64 mm3 0.41 0.71 0.92 GM.BALRCYL6 Diesel
1 BALRCYL7 Balancing Fuel Flow Rate Cylinder #7 -0.45 mm3 -0.69 -0.51 -0.33 GM.BALRCYL7 Diesel
1 BALRCYL8 Balancing Fuel Flow Rate Cylinder #8 0.48 mm3 0.45 0.64 0.81 GM.BALRCYL8 Diesel
1 VOLTS Battery Voltage 13.9 V 13.8 13.9 13.9 GM.VOLTS Battery
1 FUELRCALC Calculated Fuel Rate 10.0 mm3 8.7 9.2 10.2 GM.FUELRCALC Fuel
1 DSP5_TUNE_DMA DSP5 Tune DSP #4 . DSP #4 DSP #4 DSP #4 GM.DSP5_TUNE_DMA Diesel
1 FRPDES Desired Fuel Rail Pressure 4931 PSI 4931 4931 4931 GM.FRPDES Fuel
1 FRPADES Desired Fuel Rail Pressure Regulator Current 1449 mA 1437 1447 1453 GM.FRPADES Fuel
1 FRPADES Desired Fuel Rail Pressure Regulator Current 1.449 A 1.437 1.447 1.453 GM.FRPADES Fuel
1 ECT Engine Coolant Temperature 162 °F 162 162 162 SAE.ECT Temperature
1 ENGOILP Engine Oil Pressure 25.5 PSI 24.4 25.1 26.1 GM.ENGOILP Conditions
1 RPM Engine RPM 681 RPM 677 681 696 SAE.RPM Conditions
1 STATE15-REMACT Remote Actuation Ok . Ok Ok Ok GM.STATE15 State
1 STATE15-TAC TAC Process Ok . Ok Ok Ok GM.STATE15 State
1 STATE15-TACCOM TAC/PCM Comms Ok . Ok Ok Ok GM.STATE15 State
1 STATE15-TP1 TP 1 In Range . In Range In Range In Range GM.STATE15 State
1 STATE15-TP2 TP 2 In Range . In Range In Range In Range GM.STATE15 State
1 FRPACT Actual Fuel Rail Pressure 5049 PSI 4059 4941 5267 GM.FRPACT Fuel
1 BALRCYL1 Balancing Fuel Flow Rate Cylinder #1 -0.84 mm3 -0.84 -0.60 -0.27 GM.BALRCYL1 Diesel
1 BALRCYL2 Balancing Fuel Flow Rate Cylinder #2 1.30 mm3 0.31 0.89 1.41 GM.BALRCYL2 Diesel
1 BALRCYL3 Balancing Fuel Flow Rate Cylinder #3 -1.34 mm3 -1.34 -0.53 -0.22 GM.BALRCYL3 Diesel
1 BALRCYL4 Balancing Fuel Flow Rate Cylinder #4 2.09 mm3 0.95 1.36 2.13 GM.BALRCYL4 Diesel
1 BALRCYL5 Balancing Fuel Flow Rate Cylinder #5 -1.94 mm3 -2.36 -1.76 -1.09 GM.BALRCYL5 Diesel
1 BALRCYL6 Balancing Fuel Flow Rate Cylinder #6 1.83 mm3 0.44 0.92 1.86 GM.BALRCYL6 Diesel
1 BALRCYL7 Balancing Fuel Flow Rate Cylinder #7 -1.77 mm3 -1.78 -0.93 -0.61 GM.BALRCYL7 Diesel
1 BALRCYL8 Balancing Fuel Flow Rate Cylinder #8 0.59 mm3 0.33 0.79 1.13 GM.BALRCYL8 Diesel
1 FUELRCALC Calculated Fuel Rate 7.0 mm3 6.2 9.0 11.0 GM.FUELRCALC Fuel
1 DSP5_TUNE_DMA DSP5 Tune DSP #2 . Non DSP DSP #3 DSP #4 GM.DSP5_TUNE_DMA Diesel
1 FRPDES Desired Fuel Rail Pressure 4931 PSI 4351 4881 4931 GM.FRPDES Fuel
1 FRPADES Desired Fuel Rail Pressure Regulator Current 1357 mA 1334 1367 1452 GM.FRPADES Fuel
1 FRPADES Desired Fuel Rail Pressure Regulator Current 1.357 A 1.334 1.367 1.452 GM.FRPADES Fuel
1 ECT Engine Coolant Temperature 180 °F 180 181 181 SAE.ECT Temperature
1 ENGOILP Engine Oil Pressure 20.3 PSI 19.1 20.3 22.0 GM.ENGOILP Conditions
1 RPM Engine RPM 684 RPM 642 681 706 SAE.RPM Conditions
