LB7: Balance rate question
Dave L Weaver
Apr 5, 2011
57
Chester County Pa
Just put new 60 over injectors in and still showing crazy high balance rates on #1 and #2.:mad: Is there anything else that would make high balance rates besides a bad injector??? Does not haze at a idle but around 2k rpm it smokes a little blue. Could it be cam or crank sensor ?
pizza pig
I Like to Party
Feb 13, 2012
266
CT
any blow by? pull the oil fill cap off with it running. Copper washers sealed? Injector cups sealed?
JR WEAVER
Jan 30, 2015
12
They came from exergy performance. There is no blow by. It would be smoking more if a injector cup was leakin????
JR WEAVER
Jan 30, 2015
12
Well sounds like I might have to do a compression test. How would bad compression mess with balance rates?
Yngdmax92
962
With lower compression In a cylinder, the more fuel it needs at idle to per say keep the engine balanced. Low compression will mess with injector balance rates pretty good
JR WEAVER
Jan 30, 2015
12
Ok thanks for the info guys. Will have to do more testing.
