Badge removal/paint
06_6.6
Haulin Assphalt
Sep 3, 2012
159
Indian Territory
I'm a current member on other gmas forums but figured i'd post here as I'm changing fuels. How do you remove the badge on an 06 silly? Also what prep/paint methods and materials do you suggest? Thanks,
Sent from my PB99400 using Tapatalk 2
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
Are u talkin about the 2500hd, duramax and the side panel trim? If so I use a heat gun to warm the adhesive and it pulls off. Some residue will be left and I use a 3m eraser wheel on a die grinder. Super lightly and slow it comes off. Then just wax it after.
Be careful to not burn thru clear coat. Don't push hard
06_6.6
Haulin Assphalt
Sep 3, 2012
159
Indian Territory
I'm sorry, I meant the badge on the grille. If I do debadge I will leave the dmax/Allison badges.
06_6.6
Haulin Assphalt
Sep 3, 2012
159
Indian Territory
The factory paint/lining on the badge is peeled halfway off, just going to paint it either white or black with a clearcoat to seal it off.
arneson
Aug 14, 2011
2,133
Gotcha. I had same deal on mine. I put a billet one in but if u were to paint one, make sure there's plenty of clear coat on there. Lots of bugs and rocks hit the front often.
06_6.6
Haulin Assphalt
Sep 3, 2012
159
Indian Territory
Definitely. I drive Atleast 75 miles a day for.work so the bugs and rocks do add up. Thanks man appreciate it
1SIKDZL
Sep 5, 2012
236
Gilbert, AZ
It is pretty easy, just remove the black plastic cap that connects the grill to the core support on the top. The rest of the grill just clips in, and should pop out with a little effort. The actual bow tie is held in with 2 10mm nuts. Pretty straight forward man. :thumbup:
