Bad Injectors and a crankcase full of fuel!!!
TonOfDalt
More is better!!!!
Aug 9, 2012
153
42
Spoke Valley, WA.
Ok, So I know it says im new but in reality I have been a member for a few years now but after changing my email and forgetting my log-in credentials I just had to create a new one to regain access to the site... So its good to be back!
My full story is below but since its long I will just post a synopsis of the problem... Injectors are bad, got a new half set coming (couldnt afford a full set). Filled up the crankcase with fuel.... Would this cause any damage to the engine??? Only had it running for about 2 miles like this.
Full Story.....
Here's my dilema.... I just bought a 02 ECSB 2500HD with a LB7/ZF6 2WD combo for a pretty good deal with the knowing that it had injector or injection pump issues. Got it for $4200, high miles but clean truck.
After doing a return check on both sides I found the driverside to be WAY above acceptable so I ordered a half set of injectors and a install kit from Pensacola Diesel. The passenger sides are bad too but I couldnt afford a whole set.... I tried doing a return check on the individual injectors but didnt have the proper return tool so I opted to take out a single injector to make a return adapter on my own. Once I did this I found stampings that suggested they where newer injectors so I pulled the remaining 3 from the DS and they where all stamped alike... I couldnt resist the curosity to take one apart to see the inner workings.... :D However.... along comes my GF's 4-year old and bumps the table making parts go flying!!! :( So I had to take apart a second injector to figure out how the first one went back together. After all of this I reinstalled the injectors and started it like I normally had to (butane). Idled as normal, drove as normal.... Then I noticed my oil pressure was about 10-PSI low, and it wanted to start dieing at idle which it has never done. Next thing I know is Im leaving a trail of oil/diesel thats coming out of the fill tube! Just drained it and got about 5 gallons of oil/diesel mix out! :eek:
Getting ready to put new oil in and install the new injectors for the DS... Hope this aleviates the return problem enough so that I can at least start it without spraying butane into the intake.
Any suggestions?
TonOfDalt
More is better!!!!
Aug 9, 2012
153
42
Spoke Valley, WA.
Ok, so the new DS injectors are in and I polished the feed line ends before hooking everything back up. Truck is definately running better/smoother/quieter now and I have no fuel getting into the crankase! I still need to replace the PS injectors as it will still not start on its own (without butane) but I now have another question.... I run EFI Live and when I try to command a fuel pressure I get nothing! When its running I should be able to command anything I want and it should closely follow right??? Would this be a injection pump failing or the fuel pressure relief valve? When I am on the throttle fuel pressure rises but its about 5000 PSI below whats being commanded by the ECM... When I try to jump in and command something different I get no change.... Any suggestions?
Thanks
