I have my truck back up and running. Being a track only vehicle I would like gut the interior as much as possible. One small issue I would like to correct is with my dash panel lights - they don't work. The factory gauges work and I can data log the ECM and TCM with EFILive.
When I plug EFILive/Laptop into the OBDII port the dash lights come on. When unplugged they go off.
When I plug in the SnapOn Solus Scanner tool, the dash lights don't work and the factory gauges quit working. I can not connect with the BCM, clear Airbag codes, or connect/control ABS functions.
I am assuming I missed/eliminated a ground. I took out the Heat/AC, CD Player, all ductwork, dome & cargo lighting, and speakers. I left the Airbag controller hooked up and grounded. For now, both airbags are plugged in and the front impact sensor is still wired in and in working condition.
Any thoughts?
Any thoughts?
