Bad Fuel Leak
dirty_725
Aug 14, 2010
20
Kentucky
went out to go to work had a puddle of fuel under the truck, when its running its a constant drip onto the blacktop. its coming from the last cylinder on the passnger side of the motor closest to the firewall... the studs on the manifold are wet and everything below it.... what do ya think? thanks ahead of time
Lb7KID
ZoomZoom
Jan 24, 2010
274
parker,colo
there 2 fuel lines on the top of youer moter check there contshons or how ever it spelled:spit: sorry for the spelling also take a look at the fuel rail
dirty_725
Aug 14, 2010
20
Kentucky
ok well i found the leak today.... not good. im leaking out of the upper valve cover i found a lil stream coming out.... so this probably can't be a good thing. i have throwed a cylinder 8 missfire code a few times, but the last month has been nothing and now i have the leak?
Lb7KID
ZoomZoom
Jan 24, 2010
274
parker,colo
:confused::confused:is the fuel comeing out of the fuel line that comes from the rail into the injector? if so did you try to tightin it
dirty_725
Aug 14, 2010
20
Kentucky
ok the clip that holds the pressure line on the injector is missin. so the line backed off and was leaking..... once again another easy fix and me worrying to death.
