Ok so im pretty stumped here. Ive got a bad clunk when goin from reverse to forward and visa versa. I have only noticed it when it ahd sat on an incline or decline for a while course my parkin spot is on an incline and most places around town have a hilly parkin lot. This aint like a little clunck either. Its like some one rear ended me or i hit somethin it bangs so hard. It will only do this once per driving cycle, so untill you park it again you cant get it to do it again
here is what ive checked: U joints, no slop, binding or rust comin out; rear end gears are all tight and no abnormal wear; did this before tranny was rebuilt by mikeL aand still didnt go away; replaced carrier bearing 8 months ago and the bearing is showing some bad stress crackin in the rubber and one peice is torn some; ive greased the slip yoke at the t-case and i mean packed with grease and also the slip yoke after the carrier bearing, no change.
m runnin out of options here and this is gettin really bad. i travel alot to phoenix (150 miles each way) and dont need what ever it is breakin on me. I have noticed that the carrier bearing moves about a 1/2 forward or back with in the rubber mounting portion when put in either direction but thats all. All i can figure is that its either carrier bearing or somethin in the t-case.
any ideas? anyone know fo a bigger carrier bearing to put on cause i really dont like the factory one for what i do
