bad batteries or something else.
2008chevy2500
Sep 28, 2015
i have a 2008 chevy 3500hd 6.6 last winter 2014/2015 I had to replace glow plugs so I did. Before they started going out I started having problems with the truck loosing all power after the glow plugs cycled and I would have to turn the key off and then start the truck. most cold nights I kept it plugged in(Virginia) not too cold and it would start no problems as it wouldn't use the glow plugs. after the summer months it has started back again. i have had the batteries tested and they both read good the cca on the batteries are 770. one battery is reading 719cca and the other is reading 728cca. is it the batteries causing this or is it another problem? thanks
2008chevy2500
Sep 28, 2015
Yes i have unplugged the batteries when load tested and i drive it every day it does it on cold starts and the starter sounds fine
