so i just installed a 0-15 psi fuel pressure gauge to monitor the pressure coming from my fass. worked good when i finished the install and tested it before calling it a night. but when went to leave in the morning the gauge started boucing between 6 & 9 psi. im trying to figure out if this is a problem with my fass or the gauge.
- some other points:
1. the sending unit for the gauge is mouted on the fuel filter delete on the engine.
2. the truck does lope a little at idle, im aware that lb7's can do this as a result, and are sensitive to, the increase fuel pressure coming from the fass. this is the reason for me getting the gauge
Lastly, if anyone would mind sharing how they wired in their gauge, that would much appreciated.
