Authorization code anyone?
Philtopgun
Nice n Easy
May 5, 2007
710
45
Edmond,OK-still a Texan
Tried to uplaod a tune into efi and after clicking flash, the small red arrow, and run, after a bit I get a message stating I have to license the ecm cable. click ok, turn trk off for 15 secs, then ok, a license ecm button appears under the check status, I clicked on it, and after 2-3 mins, says program not repsonding shut down program. Did it again, this time after the 15 sec countdown, I turned the trk back on to the run position and clicked the license ecm button and same thing, program turned off....
Went to the v2 vin license, my v2 info already on there... did have an auth code box that was empty? is there a number that goes there and where do I find that number.. IM lost now..
Phil
Philtopgun
Nice n Easy
May 5, 2007
710
45
The AUTH code should be on the Blue sheet that came in your software box.
FlashScan interface, F.S. serial number, licesne type, issue date, and F.S Reg. Key.
Dont see an authorization code number anywhere on the blue form.
Went to the tutorial and saw where you copy the auth code and send it to efi and they give u a auth code to put your vin on.... Well, dont see a tab to send the auth code to efi, so i put it on a inquiry and now have to wait til a response i guess..............................................................................................................................
Also noticed every time to refresh the tab while on the auth code box, it puts a different # down there each time..
Philtopgun
Nice n Easy
May 5, 2007
710
45
Ok, since it's my first time, I have 2 license already. To send the auth code to efi, it's only to apply for more licenses. They said to follow the prompts. Well did it twice n it said vista program not responding to close program.. Anyone else have this problem?
Philtopgun
Nice n Easy
May 5, 2007
710
45
got it fixed. loaded couple tunes and hen got it back to stock. Pretty excited and exhausted at same time, trying to figure this damn thing out. Once the bugs are out, it is easy to load a tune:D
Philtopgun
Nice n Easy
May 5, 2007
710
45
Thanks, was a weird glitch I guess. I just did it again and it booted me out. Then it said the boot loader kicked me off. Took out both radio and radio amp and tried for the third time today and it worked. Next weekend Im gonna do a diy on an install, there are not any put together to help noobs who dont have someone there working with them.
