ATS Pump Kit
AdaMax
Nov 26, 2010
412
Caldwell , Oh
Does the ATS pump kit come with a converter flow valve and spring . I called their customer support and they told me it doesn't But the directions I found on the internet show a valve and spring install .
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
That's the trouble with their support. They haven't a clue what they sell. It took me 10 min to convince them that they had an updated oil supply line that was advertised on their site for at least 5 mos.:rolleyes:
AdaMax
Nov 26, 2010
412
Caldwell , Oh
yeah thats kind of what I figured . I just wanted to make sure what I am going to get before I order . I gave him the part # and I am sure he was reading off of a screen . He said they came with a pressure regulator valve ( which I assume is the converter flow valve ) But said there was no spring .
Ryan T
1,007
CA
ATS, uh oh...they are:confused:... bad news, if u think customer service is bad before u buy something, just wait till after u pay!!
15,681
ATS does not use a converter flow valve in their pump kit. They have a special pressure regulator valve that is hollow and is suppose to do two jobs at once. You use the stock flow valve with this setup.
Bryce418
Still slow
Oct 5, 2009
611
I've also heard if you have the transgo valves, not to use a copilot. Some say they dont play well together.
Personally I don't care much for the copilot on a ats trans it is not very consistent in my experience, one shift may be normal and the next a neckbreaker. Downshifts with mine were horrible too.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
I have first hand experience using the ats pump kit along with the convert flow valve from transgo in my lbz. If you want it to run hot thats the recipe!
Bryce418
Still slow
Oct 5, 2009
611
i'm pretty sure a bunch of that is the ats pump kit, my ats tranny that came with my truck runs pretty damn hot.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Well running both together makes even more heat. Did this over 2 years ago. When I first did this I drove about 20 miles on the interstate and my temps started at 170 and went to 225 in that amount of time. With the stock lbz cooler the coolest it would run was 225-220 once it got to those temps. Two huge aftermarket coolers and custom piping to make them work kept temps in check. Trans ran that combo for 50,000 miles. Left my hands that way and my friends brother put another 15,000 on it before he sold it for more money than I sold it to him for. I wouldn't run both again in a daily driver like my lbz was. In a track specific truck maybe.
15,681
Damn, beat me to it.
I would like to know more specifics on the ATS pressure regulator valve. Was it hollow on one end? The new ones are.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
To be honest I cant remember if it was, I'm leaning towards it wasn't. I remember Randy getting his and it was different than mine was and I thought it was cause his was
hollow.
Randy5.0
MAKE IT 3 YDS MF
Sep 7, 2008
292
I run the ATS valve and spring only in the pump and I really have to beat on it to make it reach 200 degrees.
