Needs to sell just sitting around its in good shape i just have no need bc i moved up to a programmer atomizer works very good when hauling loads im asking $300 obo.
You can contact me at 337-692-6805 thanks
ATS Atomizer Power Module - 2001+ GM 6.6L Duramax
The ATS Atomizer controls engine fuel rail pressures in order to maintain an optimal volume of fuel to the injectors. By doing this, the fuel droplets are introduced into the cylinders at the smallest size possible and create an efficient burn when mixed with air and combusted. Until the ATS Atomizer, pressure boxes have had a reputation for being hard on fuel systems; causing leaks, cracked injector bodies, blown seals, and poor driveability. The initial idea was great, but the execution was poor. However, that is no longer the case. The Atomizer communicates with factory equipment to drive fuel pressure up, based on engine load instead of just a fixed graph. The advantage is that it not only saves the fuel system from constant excessive pressure, but it will also retain factory-like driveablity, with substantially better top end power, lower EGTs due to proper fuel atomization, and better fuel mileage.
Engineering Matters:
- Ramps up rail pressure based on engine load
Retains drivability, where the competitors pressure boxes create too much pressure, too quickly - Has built in safety features
- Designed to work in conjunction with factory parts and not cause any premature wear or failure
- Engineered beyond the rest with in-cab on-the-fly adjustability!
