LLY: ATS 3k on my 05 lly
dirtymax36
2nd place is last
Apr 11, 2013
367
I have an 05 lly with a stock turbo on it and i just got a smokin deal on an new ATS 3k. it comes with a pedestal, braided ss oil feed line and a return line. My questions are will the return oil tube work or not because it was intended for an lb7? also where could i get an IC pipe? And would my factory intake work? (i have the lbz mouthpiece) And lastly would my diamond eye 3" down pipe work with this turbo? Any help would be appreciated im just looking to get this stocker out of here! Thanks, Brayden
dirtymax36
2nd place is last
Apr 11, 2013
367
I don't think so, it just came from Area Diesel and they have checked it and it measures 65.5mm after it was re built and finished. Its suppose to push around 40-42 psi max
dirtymax36
2nd place is last
Apr 11, 2013
367
or would i be better off selling this 3k and keeping the accessories and buying an s366 or something?
dirtymax36
2nd place is last
Apr 11, 2013
367
What other turbo would be good for a stock motor truck besides the s366 that I can use the pedestal on?
dirtymax36
2nd place is last
Apr 11, 2013
367
When you say 4088..are you comparing that to the 366 or is that the same charger? Thanks for all the help and support!
Big Chris
2 Duramaxes> 1 Duramax
Mar 30, 2010
361
46
Rives Junction MI
Get a t3 s366 like a HTT or a II silver bullet. Henry at creatures of the night will get you what you need just tell him what you want out of the truck.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
I had a 3000 before i when with the s366. I just drilled and tapped the t3 pedestal to bolt on to the t4. That was a out of the box BW S366 with .91 ar from area diesel. Yes the oil return line will work on a LLY.
dirtymax36
2nd place is last
Apr 11, 2013
367
How did the 3000 do on your truck when it was on there? And what kind of boost numbers did you make?
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
I had it on my truck for like a day, before I blew my engine and put the s366 on. The truck ran good with stock fuel, and it was not tuned (had a edge juice with attitude). I have no clue how much boost it was running...
dirtymax36
2nd place is last
Apr 11, 2013
367
Darn...hate to hear that man..do you know of anyone with an a3k on? Im really tempted just to slap it on and see how she does
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
I know quite a few Dodge guys like to use it in a compound setup. On a Duramax it is a very reliable stock replacement type charger. I wouldn't look to it for much more than that and is actually a bit smaller IIRC. In case anyone is wondering the exact specs... Here ya go
dirtymax36
2nd place is last
Apr 11, 2013
367
This may sound stupid but with a smaller charger would my egt's go up and boost numbers go down in this situation?
