ATI Damper?
dmaxlover
Mar 17, 2007
453
WI
Yes, there should be a gap. The back side of the balancer snout will bottom out on the cam gear.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
so it does require a good amount of force to install then?Did you have to modify the install crank bolt ?I am going to be buying 1 in the near fuyure and installing.
Yes it requires a goos amount of force to install. Without some sort of tool there will be no way you could get that thing on there. Its definitely going to make changing water pumps interesting.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
IIRC, you have to be very careful installing these. It's easy to get it a little cocked off, and burr up the inside of the pulley hub.
This helps with press fit anything:
Throw it in the oven at 250 deg and spray the crank tip with a can of "canned air" to ease assy. This expands the pulley, and shrinks the crank tip. No canned air? Do it in the morning when it's cold.
Diesel power
Jun 2, 2008
855
maryland
or shoot the snout with some nitrous or C02/nitrogen...
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
They might have changed these, but when I did my first, they didn't use normal eng'g practice. The first ~1/2" should be slip fit to get it started. Mine wasn't, IIRC.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
Water pumps aren't bad since its 2 piece. I tapped mine on with a big socket and then it just drew in with the crank bolt
So you leave the hub on and take the dampner part off. I was thinking about that but wasn't sure. I need to take mine off to do the electric water pump and I was going to try and do some of it tonight.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Yup. Just remember to blue loc-tite the bolts when you reassemble it.
