when installing main and head studs how critical is it to use the ARP goop? Can you substitue regular moly assy lube?
I use moly assy lube (Stalube?).
The reason to use assy lube is that it's more persistant, so that if you have problems getting oil pressure, less wear will occur. It washes off shortly after you get oil pressure.
Be sure to use plenty of lube. You will regret it if you dont and your project will take longer. Dont ask how I know.
