ARP Headstuds Needed?
BudTX
Edjumacated Redneck
Apr 8, 2007
182
MO
My 2004.5 LLY is showing symptoms of a leaking head gasket. If I keep the stock turbo, is there a benefit to ARP studs when I replace the head gaskets? I read somewhere that if I am keeping the boost under 40 psi I am OK with the stock head bolts. I'm going to replace with the C gaskets.
Stock turbo, S&B intake, egr blocked, PPE Hot +2 tuner, FASS 150, fuel shim, Suncoast Stage 4.
Thanks,
Bud
BudTX
Edjumacated Redneck
Apr 8, 2007
182
MO
Hey Josh. Nice to hear from you!
Life has been kicking me around a bit, but I'm still alive. :) I just need to get this danged truck fixed up.
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
With the rep lly's have for head gasket issues I would stud it. Also make sure you get your heads checked & surfaced.
moparkxracer
2,309
33
Out and about
You torque the heads down more with studs, they don't have the stretch to yield factor the stock bolts have. And you can reuse studs where the stock ones you can't. Just tq them down and recheck the studs after letting them sit 24 hours. The you can get a little movement when you check tq, ( do not loosen after you torque the head down you will damage the head gasket.
