LB7: ARP Head stud questions
KEVINL
1,431
Phoenix, AZ
So I just want to be clear
Thread studs into block hand tight I got that
Do I use the Arp moly lube on both ends or just the side with the nuts?
I Then torque the Studs to 125LB FT I was gonna go in steps 60-90-125
Then I have to Break them loose and then go straight to 125 3 more times Correct ?
Two more questions
With the motor in the truck I think I have to put all the studs in once the heads are already on the block due to clearance issues?
Also I can only find the tightening sequence for a LLY but all Dmax motors would be the same sequence. Right?
And Lastly my arms will be really tired:rofl:
Trippin
SoCal Diesel
Aug 10, 2006
663
1) Hand tight is fine.
2) Use the lube on the head side not the block side.
3) Use the step method each time for even clamping of the head gasket. You don't necessarily have to back them off all the way, but at least to say 50 lbs or so.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I am pretty sure only 1 stud will give you grief,Driverside firewall corner
Put the stud in the head when you install the heads to the block and you will be fine:)
Interesting thing I found is even with stretched bolts and torqed down the next morning (8 hrs) l the first stud wasnt at full torque on both heads.
KEVINL
1,431
Phoenix, AZ
So I got the passenger side on was able to put the studs in before setting the head down.
I haven't tightened anything yet because I need some 1/2" drive 12 points.
With the tightness of the drivers side I should probably leave those studs out till the heads on? And the drivers rear put the stud in with the head?
Do the ARP M8 Bolts use the factory specs for torque?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
So I got the passenger side on was able to put the studs in before setting the head down. PS is so much nicer:D
I haven't tightened anything yet because I need some 1/2" drive 12 points.Buy a good one
With the tightness of the drivers side I should probably leave those studs out till the heads on?Ya And the drivers rear put the stud in with the head? Ya
Just try putting the head on and then see what studs you cant fit in;) Those are the ones you need to leave in the head before install
The M8s I would just tq to stock spec,they are just bolts are they not? Not studs? Mine ARPs didnt come with the M8s
KEVINL
1,431
Phoenix, AZ
Yea they are bolts I was planning on reusing the factory ones but I found them at the bottom of the box. The instructions don't even mention them
ripmf666
15,123
14
47
Wentzville Mo
Off the top of my head 25ftlbs there should of been another piece of paper with there specs with your kit.The stockers are 18 ftlbs.My ARP kit had these also.
KEVINL
1,431
Phoenix, AZ
Ok I think I F***** up I put the L head gasket on the passenger side.
There goes $85
Where should the letters R and L be at the front or back of the motor and should they be facing up or face down
ripmf666
15,123
14
47
Wentzville Mo
Like this Kevin
KEVINL
1,431
Phoenix, AZ
I see "up" printed on the gasket but there are numbers next to it
I think the Right side the R is in the front and facing up
Correct?
ripmf666
15,123
14
47
Wentzville Mo
yes just think to yourself I must be able to read the(R) looking like this(R) not backwords.are you going to get a new left since to messed that one up?
KEVINL
1,431
Phoenix, AZ
Yeah the R faces towards the front of the motor and can be seen when the head gasket is on the block.
The only difference is a couple of passages are blocked in different spots so it is a easy mistake to make
The Left will be like the one in your picture.
I will be getting another Left Grade C to replace the mishap
