ARP head stud lube
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Any of you guys using a replacement for the ARP head stud lube ? Thought I had some still but it's gone and I have a new head on the block needing to install the studs.Thanks everyone .:thumb:
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
I've used redline assembly lube too. But I don't think you'll find that locally.
Haven't put studs in anything for a while, but they use to give tq specs for straight oil.
yellowchevy
1,926
82
Louisburg, KS for now
I have nothing to contribute but nice to see you're still alive Scott!!:thumb:
Did your walker tip over so you couldn't get to your computer till now??:D:D:hug::hug:
Yellowchevy
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Assembly lube? Like a grease or the oil? Cuz the assembly lube Im thinking of is a fluid, an oil, that and the ARP thread lube are two entirely different things. The ARP stud kits I have put in specifically said to use ARP thread lube, IIRC, come with it. I don't remember it giving spec for using oil as the thread lube
The ARP lube is specifically designed to allow for proper torque loading, torque distribution, and friction reduction/lubricity under exterme pressures to allow the bolt/nut to hit the proper torque spec, and not before, due to friction loading...
Im pretty sure you dont want to use oil because it can hydrolock the bottom of a bolt bore and you can pressurized the cavity as you tighten the bolt, and can wind up splitting the thread bore open, or the oil gets trapped in the bore, you can't get the bolt all the way down or later expands when getting heated up, and crack or work a bolt out...
I personally would not use a simple oil or assembly lube, for an ARP assembly lube substitute for a head stud application, they're proprietary functions are worlds apart
:2cents:
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
Thanks, I've read the ARP sales pitch before Coco.
The redline stuff is tacky, not an oil. And I'm not sure where the hydroloc deal came from, nobody said they were filling the head bolt holes with oil.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
You could always try some of this Scott, I'm sure you have some laying around! :hug:
Hot COCOAL
Jun 9, 2012
4,433
Damn
Someone needs a snickers bar
:rolleyes:
:hug:
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
:roflmao: James and Russia you guys always cracking me up.
Yeah I'm just gonna order the right stuff to much in the motor to chance something stupid I guess.Im off all this week and wanted to get it done but that's how it goes I guess.Thanks everyone for the input.:thumb:
Hot COCOAL
Jun 9, 2012
4,433
Hell I thought I was being nice, guess that's what night shift does to ya. No wonder my wife hates me
Lol
My crank broke, I'm sensitive
But a Snickers satisfies!
Maybe she needs a snickers bar, too...
One that doesn't melt, eh?
:spit:
:cool2:
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
Lol
:spit:
:cool2:
She gets plenty of that.
I understand if you want to use the ARP stuff, its your truck. What I don't understand is how everyone thinks its a godsend to the fastener world.
