Okay I had a different thread on this but now a new problem.
GOt the truck back from the mechanic not running. I got it running by changing the Crank sensor. Mechanic put 8 new bosh injectors in and a new ECM (that it didn't need $700.00)
It starts now but only revs to about 1200 RPM. than it cluts out and sounds like it misses. All the rail pressures and that stuff is right on the money. The balance rates are off at idle but it still idles good with no smoke. We put a different FICM on it and did the same thing. Tore it down to the injectors to check for wire connections for a short but that all looked okay some of the wires on the injectors were not on them straight but straightened those out and reassembled. still have the same results.
I also changed the cam sensor just for good measure.
Any suggestions ????? Any one want this thing? Make me an offer.....LOL
Have you ever heard of someone getting bad injectors new from Bosh?
After it warms up and is driven around the shop it gets a codes of p0203,0205,0208,0202 And I don't remember the code number but it is injector control group 2
