anyone tried a 1 micron fiter
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
like title says i found some 1 micron filters that they use on dispensers (like at gas stations) an they fit the fass 95 an 150 gph i thought i might have issues getting the fuel threw something that small any one else run that or any suggestions i get them at buisness cost to :D
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
Interesting, if you could find anything on what other filter heads they fit that would be awesome too. I'll be running my own lift pump setup, and plan to delete the factory filter head so I'm in the market for filters and filter heads... :thumb:
sparepartsracing
spareparts offroad&fab
Mar 17, 2010
773
i deleted my stock fuel filter assembly....piece of crap
if they fit on a airdog 150 i would run it along with my other filters....i doubt it will restrict much flow
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Micron size doesn't matter on flow;) you can have a 1000 gph 1 micron or 2 gph 1 micron
just check what the gph is before purchase.:thumb:
9,905
151
Also the larger the surface area of the filter the better. Takes longer to plug it up and it filters the fluid much better. Usually higher flow filters have more SA.
