anyone running a Kennedy boost valve lb7
bluecollar
351
ia
Hey i got a ppe valve but now won't go over 25 lbs with the new wheel.. so either a Kennedy valve or new waste gate??
Posted via Mobile Device
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Is the Kennedy valve the same as PPE's? Sounds like you need to go with a Big Head wastegate or a set of vise-grips. :eek:
Some guys have used a fish tank air bleeder think-a-ma-jig that is adjustable believe it or not. Cheap and effective :D
bluecollar
351
ia
Yes Dan it still smokes not a lot but its a good haze and totaly stock truck lift pump and new stock injectors and a hot tune now its popping the waste gate at 26lbs unhooked wg and let off at 34lbs so i wanna regulate it at 32
Sledhead
Mountain Pass Machine
Nov 29, 2008
884
BC
I've had a valve Teed into the waste gate line for years. The valve has always been wide open :woott: with the old tuner and even now with the twins and a race tune. I'm hitting 50 psi and never had a problem.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Then leave it alone.
I know that with the 7.3 Ford's when you do an aftermarket wheel it sometimes will result in a loss of boost, yet have a decent power gain. It's b/c the air the moving more efficently through the charger and requires less boost to make more power. I would bet the map on the turbo now is much different than it was before.
I would try the vice grips though if you do wanna see an instant difference.
