anyone running 63/68?
dmax404
May 16, 2011
3
Looking for a Turbo for my lb7. Mods in sig. Called fleece performance and they are recommending there 63-68 with a billet compressor wheel. I Do alot of towing and want something with quick spool up. This will be the last mod I will be doing other than head studs. Anyone here running this charger? Is it too small? Opinions? TIA
paint94979
Beer Nazi
Sep 18, 2006
11,715
do not waste your time and money of head studs... when running a turbo of that size.
carpenca
Dec 17, 2010
168
Thats poor info to put out...
The 63/68 will make 50lbs on a stock fuel system truck, and headstuds are highly recomended, especially on an LB7. A stock turbo and tunning is capable of hurting the HGs on an LB7, let alone another 15-20 PSI with a bigger turbo. Even if it were a gated housing (which would be more restrtictive which would = more drive pressure) set at 35 PSI will hurt a HG on an LB7, believe me, I know!:thumb:
We first tested our 63/68 on an LB7 tow rig, and it blew us all away as to how well it performed and responded. Its a perfect match for a maxed out EFI tune, built trans, and DD/tow rig duties.
Caleb
5,808
Caleb
Its not the boost that kills them, its the drive pressure. I ran 50-55psi on my stock headbolts with no issues till i bent a rod (i was around 600hp). Under good tuning, aftermarket headbolts shouldnt be needed but that dont mean you wont pop a headgasket, it happens sometimes.
