Anyone know where I can buy Bail Connectors
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Knowing stupid GM, those connectors are probably a lot more than 30 dollars if you buy them in less than 1000 quantity :rolleyes:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
IIRC, the smaller of the two is the one I need to play with, and perhaps the pins as well.
I might tear apart the VanAaken and use it, if my gadget works, I will need to buy about 100 of them.
Cobra#3747
Jan 2, 2007
119
Baltimore, Maryland
as long as you only need the smaller of the 2 connectors (c108 24 way connector)
the male and female side are both 3.82ea. (provided this is an acurate part number)
part numbers are
15366099
15336173
Only have one good part number for the larger connector
Cobra#3747
Jan 2, 2007
119
Baltimore, Maryland
Edit: If you turn on HTML, this will be alot easier to read :D
Connector Part Information
OEM: 15366099
Service: 15366099
Description: 24-Way F GT 150/280 Series Sealed (BK)
OEM: 15336173
Service: 15336173
Description: 24-Way M GT 150/280 Series Sealed (BK)
Terminal Part Information
Pins: A2 - A5, A7, A8, B1, B2 - B8,C1, C3 - C8
Terminal/Tray: See Terminal Repair Kit
Core/Insulation Crimp: See Terminal Repair Kit
Release Tool/Test Probe: See Terminal Repair Kit
Pins: A2, A3, A7, A8, B1- B3, B6 - B8, C1, C3, C6 - C8
Terminal/Tray: 15326269/19
Core/Insulation Crimp: E/4
Release Tool/Test Probe: 15315247/J-35616-3 (GY)
Pins: A4, A5, B4, B5, C4, C5
Terminal/Tray: 15304731/19
Core/Insulation Crimp: 2/5
Release Tool/Test Probe: 15315247/J-35616-5 (PU)
C108 Engine Harness to Chassis Harness (Diesel) Pin
Wire Color
Circuit No.
Function
Pin
Wire Color
Circuit No.
Function
A1
Not Used
A1
Not Used
A2
OG/BK
5764
EGR Motor High Control
A2
OG/BK
5764
A3
BN/WH
5763
EGR Valve Position Signal
A3
BN/WH
5763
A4
L-BU/BK
844
Fuel Injector 4 Control
A4
L-BU/BK
844
A5
YE/BK
846
Fuel Injector 6 Control
A5
YE/BK
846
A6
Not Used
A6
Not Used
A7
L-BU
6118
IAT Sensor 2 Signal
A7
L-BU
6118
IAT Sensor 2 Signal
A8
YE/BK
6120
Low Reference
A8
YE/BK
6120
Low Reference
B1
D-BU
5930
Turbocharger Vane Position Control Solenoid Valve High Control
B1
D-BU
5930
B2
L-GN/BK
5746
EGR Motor Low Control
B2
L-GN/BK
5746
B3
TN
2754
Low Reference
B3
BK
2754
Low Reference
B4
TN
1744
Fuel Injector 1 Control
B4
BK
1744
B5
OG/BK
877
Fuel Injector 7 Control
B5
RD/BK
877
B6
TN
5928
5-Volt Reference
B6
TN
5928
5-Volt Reference
B7
OG/BK
5929
Low Reference
B7
OG/BK
5929
Low Reference
B8
YE
5947
Turbocharger Vane Position Sensor Signal
B8
YE
5947
C1
WH
5931
Turbocharger Vane Position Control Solenoid Valve Low Control
C1
WH
5931
C2
Not Used
C2
Not Used
C3
GY
2703
5-Volt Reference
C3
GY
2703
5-Volt Reference
C4
YE
5422
Injector Positive Voltage Control Group 2
C4
YE
5422
C5
OG
5421
Injector Positive Voltage Control Group 1
C5
OG
5421
C6
GY
2704
5-Volt Reference
C6
GY
2704
5-Volt Reference
C7
OG/BK
469
Low Reference
C7
OG/BK
469
Low Reference
C8
L-GN
432
Manifold Absolute Pressure (MAP) Sensor Signal
C8
L-GN
432
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
but the thing is, is that the complete assembly?
Ive gone thru all the trouble of buying connectors, ordering them, waiting a couple days, only to find out its JUST the retainer, JUST the bale part etc...
