2022 chevy 2500 and I have an intermediate hard start. The engine turns over fine it just takes longer than it should to fire. First thing in the morning and if I shut it off and restart it shortly it seems to fire fine. It's after it's been parked for an hour or 2 that it seems to give me issues. I bought the truck probably about 2 months ago. I noticed it a little bit in the beginning but it's gotten significantly worse. I'm assuming a fuel pump but I've read that this code is pretty common and can be a lot of things. Truck has 63k and 2700hrs. I idle a lot, but I don't think the previous owner did. I just go me a Autel 808 scanner, but I'm not sure what I should be looking for especially since it's got 2 pumps.
Code is a 2635 fuel pump A low flow.
These are all from the fuel system data while idling.
Fuel trims look OK I guess
Fuel trim balance test failed?
MAP performance test 1 would go back and forth between Malfunction and ok: no picture
A few Ignition on Malfunctions
2 voltage References were high.
Last is a graph of fuel pressure while staying the throttle. I don't understand why desire didn't go up but I do see a dip at the beginning of actual.
If anyone can point me in the right direction of where to start looking I'd appreciate it or what websites would be good to help me flow chart how to troubleshoot this. I know there's some out there. I just don't remember what they are anymore.
