Like the title says, anybody use the Energy polyurethane trans mount? Whats your opinion on it? Good, bad, other?
Mine is a 2x4 so I'll have no added stress from the front driveline when you launch in 4x4. The only complaint I have with the Energy Suspension is no directions for the added plate that it comes with it. It would have changed the centerline from the tail of the transmission to the support bearing by about 3/16" so I left it out.
I was also wondering what that added plate was for.
Did anyone use the added plate?
I called about the plate when I installed mine. They said it was required. I told to tech it looke d taller that factory but he insisted it was needed.
The added plate is what sandwhiches teh mount together and prevents excess movement of the poly that can break them. Without it all the weight is directly riding on the poly, and poly mounts like to be encapsulated. I ran one before with my 6.5L(same mount) didn't like it. Transmitted to much vibration for my taste.
