LMM: Anybody recognize this stuff?
warpspeed
Shadetree
Feb 10, 2012
45
Ohio
Recently bought the 08 lmm & this hose was hanging off the side of the trans, it comes from the 4wd transfer case---any idea what it is for & where it goes?
& I found this weird lil socket shaped object laying on the crossmember under the oil pan---what is it?
TIA!
07bluelbz
Work Hard & Play Harder
Sep 6, 2009
742
Beaumont,Texas
Hose is a factory vent hose that should probably be secured up higher and came loose. I have no idea what the other thing is.
dieselboy04'
DieselBoy04'
Mar 23, 2008
135
Virginia
Looks to me to be a breather tube. Its supposed to be snapped in the trans tunnel above the trans if I remember correctly. Also I have no clue what the socket looking device is.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Correct about the vent. I just found out there should be a bracket that holds that hose on the very top of the bellhousing. On the stud at the bellhousing to rear motor adapter. Mine has been just hanging loose like yours for along time too
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Well i believe that hose with the check valve is most likly for the transfercase vent line and shouldnt be laying like that could be the vent line for the front diff also but that 1 should be clipped to the drivers side plastic innef fender the t case vent sould be on a steel holder and bolted to the top trans bolt which has a stud coming out of it for the steel clip to go on it with a nut.No idea what that other part is
warpspeed
Shadetree
Feb 10, 2012
45
Ohio
Cool thanks guys....glad its nothing too major. The socket thing will make a nice addition to the scrap metal pile :thumb:
13,748
821
The other thing is the piece that goes inside the starter solenoid that pulls the lever to engage the starter gear into the flywheel.
warpspeed
Shadetree
Feb 10, 2012
45
Ohio
is that something that would just "fall out" ? the starter has been replaced...
13,748
821
Not unless the solenoid was removed from the starter. The starter won't work without it.
schulte
Jul 31, 2010
449
CT
x2. Someone pulled the solenoid off the started and then dropped that plunger into the crossmember trying to re-install it.
