Any danger drilling pan for oil return?
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
If you must drill the pan with it on the engine (I don't recommend), block off the PCV vents, then hold a rag and blowgun over the oil filler to blow out chips while drilling.
Coat the drill bit with grease to capture chips.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
when i drilled mine i over filled the motor with oil and oil was flowing out of the hole the entire time i was drilling , then refilled and did the same while tapping . i changed the oil and filter 5 miles after just to be safe .
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
its fine IMO, nothing to worry about. I just dunked the tap and drill bit in grease and it worked fine. Any little bit that didnt get caught will either be blocked by the pickup tube screen, or caught by the oil filter. Plus, its aluminum; not like its gonna chew up the oil pump as steel shavings would..
mainer
Nov 11, 2008
326
dont even need to overfill with oil as trent said.... just the normal oil level will push out all the chips i highly doubt any end up in the pan with the oil flow while drilling
Randy5.0
MAKE IT 3 YDS MF
Sep 7, 2008
292
I just followed Nathans instructions with the exception of packing the tap with grease and cleaning it part way through and packing it again.
