Another Gauge Question
Oilfield_Mafia
Im the ONLY Okie..
Jun 8, 2008
162
Worlds Highest Hill
Hey ya'll, I did a search on here, but I check several forums daily and cant remember which one I saw this on, but I saw somewhere that someone put a "T" fitting in the return line of the trans so they could put a Trans temp sending unit in there. I know I dont really need the trans temp gauge, but I coudnt think of any other gauge that would be an easy install to fill the 3 hole of this pillar pod. If anyone knows where a good writeup on gauge installs for LBZ's are, please let me know. Also, those of you that have a pillar pod with gauges, where did ya'll run your wires? My Pillar pod just slides over the top of my stock a-pillar plastic, so I dont know if I need to cut a hole in it or what.. Thanks.
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
I had to drill the stock a-pillar for the wires to clear. The boost tube would kink. Then routed them into the fuse box and got power down at the fuse block that the brake controller plugs into, there are plenty of posts there you won't use. For the lights I spliced into the dimmer switch for the cluster lights (brown wire w/white stripe)
