this pass weekend i installed my transgo JR. i put 11 qt of amsoil torque-drive ATF to fill her up. after getting her all back together i got the ATF hot to check the level. it was between the two hot marks. then took her for a small drive to my parents house about 30 miles both ways and the ATF was running about 175 to 200 there and back . the truck is a CC LB LBZ 4x4 07 classic with a ppe stander set on 3, 5" mbrp down pipe back (no kitty), and a ppe cut air box with a afe filter. is the trans running hot or is that normal. it was like 110 this weekend in Beaumont too. i have never seen the trans run this hot be for even towing my friends boat up the big bear. Also did i use the right ATF?
thanks alto from the FNG
