Aluminum Rad. Overflow tank???
rdohara
Jun 17, 2009
122
Looking to see if there any aftermarket Rad. overflow tanks out there for the Duramax i cant use the stock one with the engine cage i am making and wanted to see if anyone has made anything for the Duramax
9,903
149
Check Summit Racing. I bought a sweet one off of there for about $100.
rdohara
Jun 17, 2009
122
i did not see anything that would work do you have a photo of it on your truck?
rdohara
Jun 17, 2009
122
does it use a 16 psi rad cap or is it just a cover cap with no psi? and do you by chance have a photo of it put in your truck
9,903
149
You can get any pressure you want-just ask them. I don't have any pics of it in the truck. At least not under the hood. We ended up using it for FICM cooling and mounted it in the box.
