Alternator alternate?
dracing70
SH--- GETTING EXPENSIVE!
Jun 12, 2007
1,210
45
mantua, oh
I need a Alternator that will bolt up to the stock location but is not as deep? Basically I'm looking for a more condensed alternator that will utilize all the stock mounts and hookups. Anyone have any crosses?
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
What about moving it over to the dual alternater spot and then you have all the room you need you just wont be albe to do the dual fueler
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
All the ones I've seen are the same casing.....even my 250amp one.
Might try and contact an alt reman place and see what they have to say. Mean Green, DB Electrical are 2 that come to mind.
You having piping issues?
dracing70
Jun 12, 2007
1,210
45
mantua, oh
No I can't do that. It will work where it is but it is tight real tight. A slightly smaller alternator would b the bees knees. I figured someone would know of one from another vehicle that would work.
dracing70
Jun 12, 2007
1,210
45
mantua, oh
Yes and no. I can make it work if I trim the plastic cover a smudge. Its just a lil closer than I like. I have a 4 in. Vband clamp for a connector there so it is real close if I cut off the flange and used a rubber boot it would b fine but I want a more solid connection with 60 psi of boost
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Which one do you have now? The 105 amp or 145 amp unit? I know alot of the newer trucks came with the larger AD244 at 130 or 145 amps whereas earlier trucks had the 105 amp AD230. You could probably run a small NIPPENDENSO of a TOYOTA, but not sure which one would drop in. Try giving these guys a call and tell em what you got.
http://alternatorparts.com/
dracing70
Jun 12, 2007
1,210
45
mantua, oh
Ok I'll try them out thanks
