From what I have tried on my own truck it varies quite a bit even from stock tune to stock tune. On my stock tune raising the shift points alone didn't work, it gave it a really bad hangup between the gears. I had to change the taps to get rid of it and it shifts smooth as can be now, however on Coreys truck which is an 02 changing the shift points alone it shifted perfect all the way up to 4300. But shifting it that high didn't help the perormance, and cause a lot of popping that sounded like the valves floting. I try to set the shift points to where when it shifts it falls back to the peak torque. I've tried about every imaginable rpm to shift at on mine and 3600 is the best I've found, but I don't have heads, cam and all that stuff. Just a tired LB7 and SC4 with 128,000 mi.
My opinion is anything over 3600 on a stock engine is not going to gain much if any power, but shifting at 4k makes mine sound awesome. I think with enough research the tranny can be tuned to work very well, but I think a lot of tables are not there that we need to make it do Exactly what we need it to. Thats enough for now, my fingers are tired already...so thats my opinion for what it's worth.
I was going to try to post a before and after screenshot of the difference before and after I changed the tune but I couldn't figure it out so we'll all have to go by mikes word because he's seen the logs, I think Simon has seen a couple too. I had a hangup bad enough to bounce to mph about six mph back and fourth when it shifted that I seem to have completly fixed so far. Going on 6500mi without changing it and tranny is in one piece so far.(knocking on wood) and shifting great.
Thanks Kevin, knew you'd chime in. Just took a bit of asking. lol
