Ally Locker
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
Who has one or has run one.
What has your experience been?
I have seen videos of it 'working' in jneals truck and trents truck and like what i see. But have also seen logs of it not working? I am really going to need some sort of lockup controller this year to try and push into the 11's and am trying to avoid spending a grand on an ATS copilot...
I have read a few threads about individuals experience but am wanting to hear more opinions and put together a collaborative thread.
Thanks guys!
paint94979
Beer Nazi
Sep 18, 2006
11,715
FYI A Co-Pilot with just the external harness is way cheaper than the whole Package, but it will be more than 450$... If I was you i would just wire up a ground to the TCC wire to see if it works for you. If it does go with Braydens box.
I have however yet to hear of an LBZ that didn't work with Braydens box it seems to effect LLY's the most
dmaxfireman
Apr 8, 2007
2,329
CT
hmmmmm i have locked the tcc by accident. maybe i will go with it.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
You've already ordered one so this probably is irrelevant but did you look at the TS lock up box? I've never heard of anyone having one and wondered about them as I've never heard much.
Not sure on this Nick but I don't think the TCC wants the "full voltage" of a grounded wire, and won't be good for the long term use. Could very well be wrong on that though
EDIT: plus having a switch won't be good for racing, you'd have to lock it once you've left the line and that doesn't sound like the most consistent thing on the track
paint94979
Beer Nazi
Sep 18, 2006
11,715
Guys have been running a ground to their TCC wire for YEARS i never said it was the best thing to use rather test it out to see if it works then Braydens box should work... Braydens Box did not work on my truck ONCE the way it was advertised. The Co-Pilot works plain and simple and i do not have the solenoid to internal harness so from my experience unless you want the co-pilot to handle your shifts i suggest you go the route i went.
paint94979
Beer Nazi
Sep 18, 2006
11,715
Thanks guys!
Looking at Trents log it didn't exactly LOCK, the converter was coupling just like it should be but there was no obvious proof that it worked either.
dmaxfireman
Apr 8, 2007
2,329
CT
still working with brayden to get it dialed in.... so far has not locked when it was supposed to....
paint94979
Beer Nazi
Sep 18, 2006
11,715
You using the software to change the settings?
I could never get Braydens software to properly communicate with my laptop... I don't see how changing the settings will make any difference? The parameters are already set to give the lockup command before 30mph
dmaxfireman
Apr 8, 2007
2,329
CT
yeah, lockup is not consistent. communicating fine between the laptop and the box.
i have a pwm switch that is being built for me to test if this does not work out.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
My first box didnt work, 3months later im still waiting on a new one that was finialy shipped over a month ago.....................
paint94979
Beer Nazi
Sep 18, 2006
11,715
Ya I'm not sure how some guys have gotten "AMAZING" best shop ever service and most everyone I have talked with says the exact opposite.
dmaxfireman
Apr 8, 2007
2,329
CT
it was no track test but i used it at the sled pull last week and it locked up at the right place per my tcc led.
(i am still getting my new windows 7 laptop set up and could not get the logging going in time) next one will have logs though. this week and next week i am going to be assembling and swapping out my new motor (yep its finally ready to be picked up!)
so i will post back with my track results
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Not saying it dosen't work or not but if the tires are spinning it seems that the trucks lock up. When on the pavement hooked up and all power is going through the drive train is when they seem to not lock when it should.
maddogg101920
I break stuff
Mar 2, 2007
733
CECIL COUNTY, MD
mine right now is the opposite, but ive only pulled on it once so far and im pulling again tonight so ill see if mine locks pulling or not.
