Allison Trans Temp
15,681
The factory gauge uses a sensor on the pressure switch manifold and reads heat sink which is fairly accurate. Using a sensor in the pan to read fluid sump temps is more accurate. Using the latter method will always show 10 deg cooler because it doesn't read any heat sink.
