Allison Rebuild Main Shaft not seating
BombDocDiesel
Army Bomb Squad
May 20, 2009
368
Belcamp, MD
I am almost finished with the rebuild on the Allison. I tracked down all of the balance pistons, bearings, bushings, seals and a new C5 from TKT Sales out of PA. The kit is a Stage 4 from PPE. The pump came from a new pull-out '09 Allison.
I am including most of the build up pictures. I have yet to get the mainshaft to re-seat once I flipped the Allison over. I am following step by step in the ATSG manual and I don't see where I missed anything.
It turns with a little effort but I want to make sure. The manual says 0.100" fully seated and 0.290" NOT fully seated from the top of the P2 Carrier.
Please let me know if I screwed something up.
The stand
Torn Down
I somehow deleted most of my C1/C2 pics.
Modified C2
Swapped 09 pump
Going back together
I rebuilt the extension housing assembly the morning I did the C1/C2 so I lost those pictures as well.
I'm hoping I made a simple mistake and can just take it down and try again.
15,681
You should have called me. Mainshaft needs to be supported with a fixture to hold it 1/2 inch higher. You're pulling it apart again.
BombDocDiesel
Army Bomb Squad
May 20, 2009
368
Belcamp, MD
Got it. You know what, you told me about that. I will have it apart and put back together correctly in the morning.
Thanks again Mike!
