Okay so I have established the rear adapter of my Allison cracked due to a bad u joint which I replaced the ujoint. I have completely pulled the transfer case out and then started for the housing. I'm not familiar with Allison trans internally I do suspension lifts. When I loosend the 15 or something bolts to take off the adapter housing , gears, clutches, gaskets came off with it. Not quite sure if that is normal. I honestly don't know how to put them back on in order but I made sure the clutches were in order when I removed them. Also a spinning gear with a metal ring and clip won't leave my adapter housing and is stuck with it. I honestly thought this would be just a easy replace never expected a bunch of trans parts to fall out with it. Also my truck has a 7 inch lift and I have a lot of space to work under do I still have to drop the trans in order to put the new housing on? This isn't looking good for me.
