Allison problems
lb7_dmaxx
Feb 2, 2015
Well my transmission won't shift try's to take off in high gear changed neutral safety switch and computer but nothing worked it has 8 codes with are
P0713 trans temp circuit high
P0763 shift solenoid c electrical
P0768 shift solenoid d electrical
P0773 lock up solenoid electrical
P0778 pcs b circuit electrical
P0841 tranny pressure switch solenoid c stuck off
P0872 tranny pressure switch solenoid e stuck closed
P0876 tranny pressure switch circuit stuck open
And has a tcc code when you try to drive it but with one computer the reverse light will show up and then with he other it won't and it will do the same with the drive light please help me
Awenta
4,090
CT
When/how did this happen? Or just got in one day and there it was?
lb7_dmaxx
Feb 2, 2015
Well I bought the truck with this problem but didn't expect it to be this difficult to find and its a 01 and yes everything is stock
