Allison pressure spring and shim.
techperry
GM Diesel Tech
Jun 1, 2014
47
Reading the instructions for Mike's pressure spring using the shim and spring causes faster pump and ring wear occur. My question is how fast will this occur and what all must be replaced to repair it.
15,681
Depends on how much you race the truck. The rings don't wear; it's the front rotating assembly that will get ring grooved. It will take a lot of abuse to make that happen.
techperry
GM Diesel Tech
Jun 1, 2014
47
So if mainly a daily driver it would take a while? Is the way to repair the rotating assembly or just replace?
