Friday after work, I got home and went to turn around and back up when all of the sudden the engine revs up, I look down to "shift range inhibited" flashing on the dash and the gear selection indicator flashing. There are were no codes that pulled up. During the drive home Friday, I noticed that I started to get harsh downshifts. The 2-1 shift is by far the worst. I pulled the pan off today and changed the internal filter, spin-on, pulled the trim solenoids and checked the valve movement (not sticking), put the pan back on, fuilled it up with fluid, and still the same problem. Any ideas?
