about a week ago this problem occurred. I was backing in and everything was fine, but as i slowed down, i felt the truck go into neutral, then slam back into gear. so when i put it into reverse, it will act normal and you can feel it go into reverse, but about a second later, it will go into neutral. if you press the gas it will pop back into reverse and when you let off, it goes back into neutral. i checked tranny fluid and it was correct. i unplugged the tranny harness and the problem went away and it acted great. what do i need to change?!?
