allison pids ?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
i was wanting to log the trans this past weekend and i didnt have any pids ? were do i get the pids ? are they suposed to populate when i hook up to the allison controller ?
mainly looking for pids related to lock up so i can post some logs with the lock up controller on and off for people to see if they are interested in them or not .
Jasondt2001
May 3, 2008
373
Salinas, Ca
As far as I know the only way to log it is through the black box logging feature (The stand alone V2 type).
There's quite a few things it'll log BBL that it won't let you with the laptop (the pass through logging).
When's the last time you updated your efilive software? They've made some changes (For the better!) and you might be missing out on them.
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
You dont need BB to long the trans. Just make sure you are up to date and select the correct controller. You may have to validate the pids. I think I have close to 100 pids for my 6 speed but dont quote me on that.
TrentNell
Jul 7, 2008
7,543
slc tuah
i may be SOL i have a V1 , its onkly been 1.5-2 mounths since i updated . if not i can log it with MY HP Tuners right before i ship it off to the buyer and just do a screen snap shot for the info .
TrentNell
Jul 7, 2008
7,543
slc tuah
how ? no trans pids were in the list to choose from when i hooked up to the allison controller .
Jasondt2001
May 3, 2008
373
Salinas, Ca
Sorry! That must have changed since I tried it last time (a while back)...
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
EFI V2 Scan only is also avail. You can then log the Allison.
you can upgrade to the V2 scan and tune or you can purchase the scan only V2 which can later be upgraded to the scan and tune...
Thought I'd throw some options out there for ya, as you are kinda limited with the V1.
TrentNell
Jul 7, 2008
7,543
slc tuah
to be honest it just will not happen then , i have no need for my self to log it , and have access to a tech 2 for repairs . i will just get some screen shots with HP Tuners and post up to show a comparison on lock up . thanks for the help guys !
FlashScan V1 supports logging for all controllers that it supports for tuning. You will be able to log your Allison 5 speed, but you won't be able to log or tune an Allison 6 speed. To get you up and running, below are some suggestions:
Make sure you are selecting LB7/LLY Allison TCM from the drop down list.
Try validating the PIDs for the Allison controller. To do that select the menu option Info->Validate PIDs while connected to the Allison.
There is a not so well known bug in the software that can cause the "validated" PID list to remain as the ECM PIDs even after you tell EFILive you want to work with the TCM. To get around it, after you connect and select the Allison TCM controller, click on one of the column headers in the [PIDs F8] tab page to re-sort the list by that column. Doing so will cause EFILive to refresh the list and disaply the correct validated PIDs for the selected controller.
Let us know how you go. The age of your software shouldn't be the reason why logging won't work, but at some stage you should update.
Cheers
Cindy
