I was doing a Ford vin check and I saw this recall by Ford:
Number
8V01
Vendor FSA Notice
200
200
8 F650 and F750 Trucks
With
Allison Transmission
Park Paw
l Actuator Assembly
Inspection and Repair
Date:
Date:
May 1, 2008
INFORMATION ONLY
This Is
This Is
a Vendor Field Service Action Notice
Assembly
Plant
Af
Af
fected Vehicles
2008
F-650 and F-750 trucks
equipped with Allison
transmissions
ESCOBEDO
(MEXICO)
Certain vehicles built from
November 16, 2007 through
December 11, 2007
Issue
On the affected trucks, Allison Transmission Corporation has determined that a very
small number of transmissions may have been produced with a non-conforming park
pawl actuator assembly. The non-conforming assembly may cause higher effort in
moving the shift selector out of park.
Action
1. Allison Transmission Corporation warrants the transmission park pawl actuator
assembly and is conducting a Product Satisfaction Field Action to inspect and, if
necessary, repair the park pawl actuator assembly in the affected trucks.
2. Allison Transmission Corporation has contacted all Allison distributors and
authorized service centers (including authorized Ford dealers). Allison is
providing these facilities with parts, technical instructions, and claiming
instructions for the inspection and repair of the park pawl actuator assembly.
3. This notification is for your information only. Allison Transmission Corporation is
conducting the Product Satisfaction Field Action and Ford Motor Company has no
administrative responsibilities for this action.
4. DO NOT SUBMIT WARRANTY CLAIMS TO FORD MOTOR COMPANY.
5. Allison Transmission Corporation has also sent all affected owners a letter asking
them to have the transmission parking pawl actuator assembly inspected and if
necessary, repaired at an authorized service center.
NOTE
transmissions
ESCOBEDO
(MEXICO)
December 11, 2007
Issue
Action
NOTE
: OASIS is activated to help dealers identify which vehicles may be eligible under
this program. Because this is a program being conducted by Allison Transmission
Corporation, the Open/Closed status in OASIS will not be updated as vehicles are
repaired under the program. As a result, dealers must verify vehicle eligibility with
Allison Transmission Company (800-252-5283) prior to performing repairs. Claims are to
be submitted directly to Allison Transmission Company.
Questions? Allison Transmission Call Center: ………………….…………800-252-5283Corporation, the Open/Closed status in OASIS will not be updated as vehicles are
