Allison fluid level
eatfire
Feb 12, 2016
I just had a service done on my 2016 3500, DRW 4X4 truck at a dealership. I have the Duramax with an Allison trans. The dealership filled the trans to the full cold line on the stick. This seems a little low to me. I do realize this is probably the recommended fill point, but even when the transmission warms up the fluid level does not change, let alone expand to the full hot line. Am I just being paranoid? By the way I do tow a very large horse trailer with this truck, and I don't want to have an issue. Thanks for any advise.
Tothemax
xgmtech
Oct 16, 2014
607
new york
its fine. the fluid will be close to the hot mark when the trans temp gets to about 180-200. Allisons would rather be a touch low then over filled
BoiseRob
392
45
Allison's run a bit cooler if they are not filled completely full. Check hot and the level should be near the low mark. Is that correct Mike?
