Hi everyone I am trying to get my brain around this C1 clutch and how to not tear it up again. I have allways pulled in 1st gear high range because we can not get a 3rd gear start to work on my 2009 lmm. I have the A50 controller so I had an A40 TCM programed for a 3rd gear start that I would swap for the A50 at the trac but I have one of the lmm os that will not accept the A40 TCM and goes crazy every time I plug it in. So I am stuck with 1st high range.
So I need so help to see if I am looking at the power flow through the Allison right.
C1 is 1st gear and also acts as a forward clutch to the other foward gears. C1 is applied in all forward gears.
So let's say I have my truck hooked to an object, my gear selection is high range first gear and it took 500hp to get the truck to move. OK the C1 clutch had to hold 500hp all by itself.
OK now I am not to sure about this next part.
I hook onto the same object but geared in low range 3rd. Now by doing this the affective gearing from the input shaft to the driveshaft is almost the same as 1st high range and will still take 500hp to get the truck to move. So the C1 clutch is still going to have to handle the same amount of power either way.
So I guess the million dollar question is how going to a 3rd gear start going to protect my C1 clutch.
Rick Abare
Rick Abare
