What's the cost on mike trans shipped? I don't got time to drive down there and I think the lml trans is done. It's a 2015.5
You would be way better off to drive down there. If you don't properly flush the coolers after a failure, it can cause problems with the new transmission, and it isn't something you can do at home yourself without buying some expensive equipment.
Also you know it will be done right and it will be fun hanging out at the shop with MikeYou would be way better off to drive down there. If you don't properly flush the coolers after a failure, it can cause problems with the new transmission, and it isn't something you can do at home yourself without buying some expensive equipment.
X2Also you know it will be done right and it will be fun hanging out at the shop with Mike
Sent from my XT1635-01 using Tapatalk
